Did oil pressure test.
Decided to do an oil pressure test to see how healthy the oil pump is, after all it is a '03. I did the cold numbers after the truck had sit for several hours, so it was not as cold like sitting overnight.
cold idle: 53
cold 2000: 56
Hot idle: 14
hot 2000: 48
how do these numbers look?
thanks
cold idle: 53
cold 2000: 56
Hot idle: 14
hot 2000: 48
thanks
Look very sim to mine. I may be a pound or two higher on cold idle but they might just be the gauge. I get as low as 12 or so on really hot idle. I just changed to 20w-50 though so I don't know what I get now. I'm sure it's higher though. I can hear it in the engine. Runs a lot more quiet.
My mechanic who's an independent Land Rover guy says they are recommended by Land Rover to use 20w-50. I don't see many guys on the forum running it. Seems like it would just lower your gas mileage. Im in NC so the climate doesn't get too extreme either way.
Is it just a safe oil in case something drastic happens?
DiscoBenjamin
06-13-2011 02:20 PM
