it die while running
Hey guys I need your help again while we was heading to get some to eat tonight our rover just die no power what so ever so I had to cost it in a parklot and let it sit for 10 mins and it want to crank over but nothing so when my buddy got there I was mess with the spark plugs wires near the dist cap and it Crank over for a second then die again so I am thinking it is plugs and wires
When was your last tune? You do not have a distributor. One wire will not kill the truck, but it wouldn't hurt to replace them with some good 8MM wires ( I use Magnacor) and bosch +4 plugs.
You are most likely looking at a crank sensor. If it gets warm and dies, but will restart after cooling off, only to die again, that is it. $60 part and about 30 mins to swap.
Update while we are waiting on fuel pump come in her daddy pull the fuel pump out and got it test don't ask how you test the pump like that but he told us it was good so I go head a replace relay and fired right up and ran for 5 mins so I shut it off and now nothing so it got be fuel pump
Vertigo RT
08-20-2010 06:04 PM
