Replacement Hub and sensor (new or used)
Old Feb 22, 2010 | 09:27 AM
tbesselman's Avatar
Default Replacement Hub and sensor (new or used)
I have a 99 Disco II and need to replace the Hub and Sensor, and wanted to get everyones thought on whether to buy it from Roverlands (used for $225) or new From British Atlantic for $400. I don't want to be penny whise and pound foolish and be stuck replacing it again in 6-12 months...Thank you for any input you guys may have.
Old Feb 22, 2010 | 10:40 AM
kenk's Avatar
Call and ask if they know how many miles are on it. If it's close to what you have, i wouldn't bother. Give this guy, Will, a call, he always way underprices roverland.
http://www.roverguy.com/
Only $25 diff, but check these guys out for new parts,Terry is awsome to deal with
http://www.rovahfarm.com/DiscoIAxles.htm
Old Feb 22, 2010 | 11:11 AM
Just curious, why do you feel you need to replace the hub?
Old Feb 22, 2010 | 11:33 AM
lipadj46's Avatar
You should be able to get a low mileage used hub and sensor for $125 shipped don't be afraid to haggle. Call Justin at Lucky 8, will Tillery (roverguy.com) or paul grant (look over on LRO classifieds for email).
Old Feb 22, 2010 | 11:42 AM
tbesselman's Avatar
Disco Mike - I did my diligence this time .....I've been getting the three amigos, and here is the fault. I don't know how to tell wheter it is the Hub or the sensor....so I was going to replace both. I'm open to ideas though.....
|* ABS Amigo Box V1 RSW Solutions LLC Copyright 2008. *|
|* www.RSWsolutions.com *|
|* Version V1.1 *|
1.--Current Faults---->
Active Faults:
None
Logged Faults:
Front Left Sensor Bad Output
<-END Faults
..--Previous Faults--->
Active Faults:
None
Logged Faults:
<-END Faults
Active Faults:
None
Logged Faults:
None
<-END Faults
Old Feb 22, 2010 | 12:23 PM
tbesselman's Avatar
Guys is the Hub replacemnt a DIY - or do you need some special tools and know how?
Old Feb 22, 2010 | 02:41 PM
lipadj46's Avatar
Its easy but you need a large breaker bar and socket to remove the hub nut and then you need a torque wrench that goes up to 360 lbs. You also should have a 3 legged gear puller.
http://www.discovery2.co.uk/fronthub.html
KlamathMatt
Apr 17, 2020 05:27 AM
ukwildcats
Jul 8, 2013 07:08 PM
ewok
Apr 5, 2011 02:49 PM
mattyh007
Sep 17, 2009 02:07 PM
lipadj46
Mar 25, 2009 11:53 AM
