it die while running
Old Feb 16, 2010 | 11:51 PM
JumPeR04's Avatar
Default it die while running
Hey guys I need your help again while we was heading to get some to eat tonight our rover just die no power what so ever so I had to cost it in a parklot and let it sit for 10 mins and it want to crank over but nothing so when my buddy got there I was mess with the spark plugs wires near the dist cap and it Crank over for a second then die again so I am thinking it is plugs and wires
Old Feb 17, 2010 | 12:05 AM
roving patrol's Avatar
or distributor! or pick-up coil! or your fuel pump!......there's a lot of causes for your truck to stall like that!
Old Feb 17, 2010 | 08:20 AM
okdiscoguy's Avatar
When was your last tune? You do not have a distributor. One wire will not kill the truck, but it wouldn't hurt to replace them with some good 8MM wires ( I use Magnacor) and bosch +4 plugs.
You are most likely looking at a crank sensor. If it gets warm and dies, but will restart after cooling off, only to die again, that is it. $60 part and about 30 mins to swap.
Old Feb 17, 2010 | 10:55 AM
JumPeR04's Avatar
It is the fuel pump so I am going order a new one but do I go with non or evap one
Old Feb 17, 2010 | 11:44 AM
okdiscoguy's Avatar
evap.
Old Feb 21, 2010 | 07:25 AM
JumPeR04's Avatar
Update while we are waiting on fuel pump come in her daddy pull the fuel pump out and got it test don't ask how you test the pump like that but he told us it was good so I go head a replace relay and fired right up and ran for 5 mins so I shut it off and now nothing so it got be fuel pump
Old Feb 22, 2010 | 08:41 AM
okdiscoguy's Avatar
It may run for a bit and shut off. Ususally happens when the tank is lower on fuel. The fuel cools the pump.
Old Feb 22, 2010 | 11:13 AM
JumPeR04's Avatar
Ok thanks I can't wait to prove them wrong but I will let know what happen
Old Feb 22, 2010 | 11:22 AM
You might want to wait on doing anything. First, rewrite your first post so we can get a better idea what is wrong. Do you have any fault codes, when was the fuel filter last changed?
Old Feb 22, 2010 | 02:28 PM
tornado_735's Avatar
Sounds to me like it might be a crank position sensor.
dev99disco
Aug 31, 2010 07:46 AM
Vertigo RT
Aug 20, 2010 06:04 PM
vandev
Aug 2, 2010 06:23 PM
yloDiscoII
ROAMING WITH FRIENDS
Jun 22, 2010 06:54 AM
roverwoody
Sep 20, 2008 03:43 AM
