Died While Idle, Won't Start
#31
Hi Robert- could be bad grounds - I had a situation where my speedo would drop to zero everything else was fine, ECU was still working. After a week on this I found if I turned enough power on I could make happen - the heater blower motor was ideal.
Turned out to be 1 single loose ground in the engine compartment, I have been slowly hunting all the grounds down and checking them.
As far as I can determine these trucks react weird to ground faults.
I believe your odometer info is stored on the ECU - no ECU no Odometer
robert.juric (10-03-2017)
#32
Man I'm really torn about this, but I feel like I keep getting conflicting info. This morning it started up fine (I wanted to make sure it warmed up ok). I went back out to go for a drive 30 minutes later and it wouldn't crank.
I put in the iCarsoft to watch the live data as it cranked and it wasn't reading any RPM while cranking (should it?). I think I'm going to eat it and buy a new Bosch CkPS next week. I may even spring for genuine. It's kind of starting to bug me that its not reliable right now.
#33
Sounds like yours may be bad?
#34
#35
#36
I replaced the CkPS today and so far it looks like a fix. I'd have to thank wjsj69 for pointing out that not all CkPS die a clean death. That and a lack of RPM reading when I was having problems cranking lead me down this path.
I'll be keeping a close eye out for this issue. I ended up getting an off-brand from Oreilly's since it was in stock and had a lifetime warranty.
I'm going to knock and wood and call this resolved.
RoverLady
04-26-2012 08:56 PM
