Died While Idle, Won't Start
Old Oct 2, 2017 | 12:42 PM
  #31
Richard Gallant's Avatar
Hi Robert- could be bad grounds - I had a situation where my speedo would drop to zero everything else was fine, ECU was still working. After a week on this I found if I turned enough power on I could make happen - the heater blower motor was ideal.
Turned out to be 1 single loose ground in the engine compartment, I have been slowly hunting all the grounds down and checking them.
As far as I can determine these trucks react weird to ground faults.
I believe your odometer info is stored on the ECU - no ECU no Odometer
Old Oct 3, 2017 | 11:24 AM
  #32
robert.juric's Avatar
Man I'm really torn about this, but I feel like I keep getting conflicting info. This morning it started up fine (I wanted to make sure it warmed up ok). I went back out to go for a drive 30 minutes later and it wouldn't crank.
I put in the iCarsoft to watch the live data as it cranked and it wasn't reading any RPM while cranking (should it?). I think I'm going to eat it and buy a new Bosch CkPS next week. I may even spring for genuine. It's kind of starting to bug me that its not reliable right now.
Old Oct 3, 2017 | 02:09 PM
  #33
BackInA88's Avatar
It's my understanding that's the only way to check for a bad CPS since it throws no codes.
Sounds like yours may be bad?
Old Oct 3, 2017 | 02:26 PM
  #34
This would be the 2nd bad CkPS to my knowledge in this vehicle. Once by the previous owner, once by myself about 1k ago and now there is a good chance its happening again.
What's the best to get? Bosch? OE?
Old Oct 3, 2017 | 03:49 PM
  #35
BackInA88's Avatar
This is the one I bought here.
I find an online coupon and pay for it with paypal on their website and pick it up at the store.
I think I got it for under $40 bucks a couple years ago?
Old Oct 12, 2017 | 05:27 PM
  #36
I replaced the CkPS today and so far it looks like a fix. I'd have to thank wjsj69 for pointing out that not all CkPS die a clean death. That and a lack of RPM reading when I was having problems cranking lead me down this path.
I'll be keeping a close eye out for this issue. I ended up getting an off-brand from Oreilly's since it was in stock and had a lifetime warranty.
I'm going to knock and wood and call this resolved.
Lgolf81
LR2
53
Sep 7, 2023 01:56 PM
malibuman09
Nov 18, 2012 01:59 PM
RoverLady
Apr 26, 2012 08:56 PM
blaze98
Oct 2, 2010 02:56 PM
kayaku
Jan 18, 2009 10:24 AM
