Diff lock switch
Old May 28, 2020 | 04:55 PM
batstang's Avatar
4th Gear
Default Diff lock switch
Hi folks! 04 disco 2 with 235k miles. Just replaced the switch and the light stays on. Is this a switch that needs to be shimmed with washers? I bench tested it and the switch works. the factory switch had only one washer. I thought that it was simple replace type situation. Any insight would be greatly appreciated. Part #IGM500011
Old May 28, 2020 | 06:35 PM
JUKE179r's Avatar
Is the CDL engaged?
You might have to check the RAVE Manual for the switch install. I know it’s not supposed to be cranked down into the transfer box.
Old May 28, 2020 | 10:11 PM
batstang's Avatar
4th Gear
Hmm. I see. The switch I removed took a socket to remove. It was in pretty tight. I guess tomorrow, ill pull the console and do a trial and error adjustment. Fact is, the light is on, but the diff is not locked. Nor will it lock. Ive had no issue with its actual operation until I installed the switch, lol.
Old May 29, 2020 | 10:30 AM
batstang's Avatar
4th Gear
Solved. I had overtightened the switch. Stock washer was adequate. I removed the cable from the lock and moved the lock through its full range of motion-- the cable does not do so. I think working it helped with the movement within the case. I reinstalled the switch with less final torque and it works fine. I verified by lifting front wheel and rotating locked and unlocked--all was well. Thank you JUKE179r for your reply.
acg
Apr 28, 2020 12:53 AM
mjbrox
Dec 10, 2014 09:35 PM
ktm_525
Sep 4, 2012 10:43 AM
Diverjohn
Feb 9, 2011 01:42 PM
chad420
Oct 26, 2009 03:50 PM
