Center Diff Lock Switch
Old Oct 20, 2015 | 03:14 AM
acg's Avatar
acg
Default Center Diff Lock Switch
I installed CDL into my 2003 Disco a couple of years ago. At the time, I had forgotten to order the following diff lock switch parts:
Differential Lock Switch On Transfer Case (PRC2911 Same Fit As Part # PRC2911-LUCAS ) - Land Rover switches/control unit/actuators from Atlantic British
Differential Lock Switch Harness (Genuine Part # YMQ105170 ) - Land Rover switches/control unit/actuators from Atlantic British
I now have these parts and would like to install them. The diff lock switch harness has two spade connectors which go into the two prongs on the diff lock switch.
Does anyone know where the single white plastic connector should go (as shown by the arrow in the second pic)?
Attached Thumbnails Center Diff Lock Switch-diff-lock-wiring.jpg   Center Diff Lock Switch-diff-lock-switch-harness-part-number-ymq105170g.jpg
Old Oct 20, 2015 | 07:59 PM
acg's Avatar
acg
Anyone?
Old Oct 20, 2015 | 09:20 PM
lordmorpheus's Avatar
Do you have Rave? I did a search for ABS wiring and found the connector for the diff lock switch. Then searched connector number to get this.
Old Oct 21, 2015 | 02:38 AM
acg's Avatar
acg
Dave,
I looked through the RAVE under the transfer case section. There was no specifics on the connector location.
I will take another stab at the RAVE. Thanks for the info!
Old Apr 28, 2020 | 12:53 AM
Ivan0z's Avatar
Ever have any luck ? I'm trying to buy that part but have no idea where the white part connects 2
cornbreadj
Dec 27, 2014 07:50 PM
Doug18
Sep 22, 2014 11:39 PM
Nodric
Apr 27, 2013 03:50 PM
tornado_735
Aug 7, 2010 12:39 AM
Mrmerlin
Dec 9, 2009 11:33 AM
