diff oil change
Old Dec 21, 2008 | 11:35 PM
old gold's Avatar
Default diff oil change
1998 Disco 167k miles
I've drained both front and rear differentials.
2 easy questions
1. Rave calls for 3.6 pints front and rear ( British 20 oz. pint I presume)
Should I just keep adding until I reach the fill hole?
2. I was going to add some 1/2' or 3/8" hose to the nipple on the quart of gear oil so I can get r' in there.
Any other brighter ideas??
Old Dec 21, 2008 | 11:42 PM
sloppyjoe's Avatar
Default RE: diff oil change
ORIGINAL: old gold
2 easy questions
fill to the fill hole and you can get a small pump for gear oil at most auto stores
Old Dec 22, 2008 | 06:35 AM
Also make sure to clean of the metal on the magnetic drain plug.
Old Dec 22, 2008 | 09:48 AM
04BluDisco's Avatar
I just jammed the spout of the container into the hole and squeezed until nothing more came out. Then I put the second one in and squeezed.... when I couldn't get any more out, I filled up the second container with the residual from the first and squeezed again. Worked well... zero mess....
J
Old Dec 22, 2008 | 10:19 AM
How about your other fluids, have you done them yet? T/case, brake fluid, p/steering fluid, tranny and coolant, need any help, just shout.
Old Dec 22, 2008 | 11:35 AM
redhotbuzz's Avatar
Youre gonna need a pump for tcase.. autozone has a nice one for 15 bucks . Two bucks less then Mobil 1 140 synthetic gear oil...
Old Dec 22, 2008 | 12:51 PM
old gold's Avatar
I just picked up a 12$ bilge type pump at Autozone.
Mike in regards to replacing fluids so far:
engine oil
diff fluid
brake fluid
coolant
Next up: transfer case and transmission
The power steering is leaking so badly I need to sort out the leak first.
John Garcia
Mar 20, 2019 07:19 AM
MeanSaleen
Aug 26, 2013 10:16 AM
collin Barrows
Aug 28, 2011 07:13 AM
mwindth
Dec 21, 2010 08:28 AM
Disco2Guy
Jun 20, 2008 10:13 PM
