Diff/TC oil change
Hey all. Question will i be able to change the front/rear diff and transfer case oil with the truck on the ground? How much of a pita will it be? Thanks :
I did mine on the ground, no problem. a transfer pump is highly recommended.
a 2" lift helped also, but not a must. http://www.tooltopia.com/mityvac-mv7...Fevm7AodKV4AoQ
a 2" lift helped also, but not a must. Save on Mityvac - MV7241 at ToolTopia.com
You will need a wobble extension for the fill plug on the t-case. I have the same pump it did not like the heavy 140 weight gear oil, it kinda exploded on me but lasted for the job, I also used 4 4x6 wood beams as ramps and raised the truck 4". Took me about 1.5 he's to do the case and diffs. If its a hot day sit the bottles in the sun for about an hour before you start, thins it out just enough to make it easy to pump.
Happy wrenching!!
Happy wrenching!!
