Difference between CDL and ARB lockers
Is the Discovery CDL similar to ARB lockers? The CDL once engaged, does it lock all four wheels? I saw that ARB lockers are separate from the rear and front if installed. Each locker distribute power to both wheels, right? So the CDL, locks all four? Can anyone explain?
Thanks
Thanks
So, in essence, a locking differential in your wheel axles does you no good without having the transfer case differential locked because the power is being transferred to the path of least resistance so that the locked diff of the 3rd member never gets any power to begin with.
This is only good for use off-road because the characteristics of a "locked" driveline are terrible for everyday, street use. The front tires must be able to rotate at different speeds from each other and from the back tires so that you can steer and turn your vehicle accordingly. Any differential that is locked in any part of the driveline is pretty much made to only drive on a straight path and forwards, the majority of the time.
LR03NJ (02-20-2016)
Now as I understand if the CDL is engaged it will lock the front (which is still an open differential) and the back (also still an open differential) combined. So the power can be distributed diagonally (equally front and back) in a situation when the (front left tire) and the (rear right rear) tire is above ground, so then the rest of the tires touching the ground has equal amount of traction. Also, then if that is engaged it will still drive normally while turning. Also, its not like the concept of ARB which completely locks the front or the back.
Sorry, sometimes I'm mechanically challenged. I dont do off road and have an 03 and 04 which has some minor differences which I want to understand.
Thank you again.
Thank you again.
Thank you again.
Thank you again.
They say only serious off-roading and serious obstacles necessitate the need for locking 3rd member on a Discovery WITH center-locking diff. Are you thinking about modifying your transfer case to a locking unit? I just picked up the parts to do mine today.
Put slightly differently, with the transfer case (center) differential locked you should have power to at least one front and one rear wheel. They may both spin and leave you stuck but it's better than having power to just one spinning wheel and the other three wheels not moving at all.
krazy92683
01-30-2008 05:36 PM
Roverboy3766
11-10-2007 03:22 AM
woodsrider
12-11-2006 07:54 PM
