Difference Between Discovery and Range Rover?
Old Dec 11, 2006 | 04:21 PM
F451_Guy's Avatar
7th Gear
Default Difference Between Discovery and Range Rover?
Hi,
Newb here. I tried searching for the differences between the Discovery and the Range Rover, but I could not find any threads on that.
In any case, can anyone tell me the basic differences between the two? I'm considering getting a used (1996 or so) SUV for commuting and the occaisional easy off road ride (forest roads). I'm pretty good with a wrench, so no worries on maintaining it, I'll do as much of the work on it as possible.
I haven't even sat or really looked at either the Discovery or Range Rover, but I've always like them, so am considering them.
One thing, I'm 6'6", so if one has more head room, that would be good to know.
Any input or tips would be greatly appreciated. Thanks!
Ed
Old Dec 11, 2006 | 07:53 PM
Default RE: Difference Between Discovery and Range Rover?
I would suggest you go drive both first to at least get a feel for them then ask more specific questions.
Mike
Old Dec 11, 2006 | 07:54 PM
justfred's Avatar
At 6'6", you'd want a Range Rover, I'm pretty sure it has better headroom and it definitely has more legroom.
Basically, the Range Rover is the "high end" model - everything is a bit more luxurious. It's also a little wider.
A ~1996 Range Rover should be $2000-$10000 depending on mileage and use; a Disco may be around the same (my '98 sold for $3000 with 175,000 miles and a fair amout of off-road use but cosmetically decent). Most have (shamefully) never been offroad. Parts and service should be around the same cost for either. There were a lot more Discos produced, I believe. If you can get one with less than 100,000 miles, that'd be good; there are some major components that should be looked at around that point. Most of the gremlins in the Rovers seem to be in the minor electrical systems - window motors, light switches, seat switches. If the previous owner has been good about doing service every 5000 miles or less the drivetrain should last a long time; the usual things like alternators, pumps, etc usually last longer than Japanese versions; the Rovers leak oil and fluids a lot more, though, and if you don't watch that there might be problems - or as they say "if it's not leaking, it's empty." Range Rover mileage may be a little less; expect 12-14 vs 13-15 in a Disco.
I rolled an 84 Range Rover, and not only was uninjured, but managed to drive it home (it later dropped a piston, but that's my own stupidity for not blowing the oil out the cylinders after rolling it!). Really sturdy vehicles.
luxury1
Apr 17, 2009 12:58 PM
Disco2Fever
Oct 8, 2008 09:49 PM
ste.s
Feb 14, 2008 12:36 PM
krazy92683
Jan 30, 2008 05:36 PM
Roverboy3766
Nov 10, 2007 03:22 AM
