Different weird blinker issue - 1 pulse only
Old Jan 20, 2019 | 01:53 PM
Extinct's Avatar
Default Different weird blinker issue - 1 pulse only
So I am slowly working through the issues with the latest 03 I picked up, but this issue has me baffled. Right blinker works fine, left and hazards do not. When I try to use the left or hazards I get one blink pulse only on the dash, one click under the dash, and no lights exterior.
Changed so far:
Interior fuse box
Blinker stalk switch
Disconnecting taillights and headlights makes no difference.
Anyone ever seen this? I am beginning to suspect the ECU.
Old Jan 20, 2019 | 02:28 PM
No Doubt's Avatar
Inside the back hatch area of your Disco 2 on the passenger side is a plastic vented cover on the corner vertical pillar.
Pop it out and look inside.
I had a small electronics box in there that had a ground screw holding it on to the frame, except that it had come loose. I got really odd behavior from my taillights and brake lights until I found and screwed that ground screw back tightly onto that box.
abran
Dec 7, 2019 08:07 PM
MagnoliaLandy
Feb 13, 2015 11:02 PM
filthydisco01
May 22, 2013 01:04 AM
C Trus
Jun 19, 2011 01:20 PM
jdelp
Apr 26, 2007 10:21 AM
