Differential fluid 75w140 versus 80w140
Old Feb 2, 2024 | 03:02 PM
NVDiscovery's Avatar
Default Differential fluid 75w140 versus 80w140
I've switched to a heavier differential fluid to reduce transfer case leakage. For some reason, I have both Redline 75w140 and 80w140. I have a differential/transfer case fluid change coming up soon. My assumption is that I could use them together. Any concerns? And which is preferable going forward.
Thank you.
Old Feb 2, 2024 | 05:53 PM
Extinct's Avatar
Given your location go with the heavier weight. Minimal difference anyway but in SC the heavier will leak slightly less, cushion slightly more.
Old Feb 2, 2024 | 09:28 PM
disco96sd's Avatar
makes zero difference
Mariah
LR4
Aug 12, 2021 10:36 PM
Mechano2020
Aug 5, 2021 03:13 PM
solarpower44
LR2
21
May 21, 2019 09:04 PM
joefresso
Apr 25, 2011 07:18 PM
krazzz
16
Nov 17, 2009 11:33 AM
