Differential's expalined
The TruTrac actually seems the works pretty simple. Under normal operation there is space between the pinion gears which allows the side gears to turn at their own speed, like a normal differential. As the side gears turn at different speeds the pinion gears move closer together until the speed differential is great enough that the pinion gears contact each other and therefore cause both wheels to be driven. All of this occurring inside the differential unit which has the ring gear bolted to it and being driven by the driveshaft via the pinion gear.
Not sure if that actually helps anyone understand but I hope it does.
GM for many years has used the Eaton Govlock as the limited slip differential in its line of full size trucks. It is my understanding that the Govlock is actually closer to a full locker than a limited slip and is nearly bulletproof. Under normal conditions the Govlock stays locked and only unlocks under specific circumstances, such as rounding a corner. The best part of the Govlock is that it does its job silently unlikely a lot of aftermarket lockers. The Govlock is one of the few things GM managed to get right.
Hey spike, what options do we have as disco owners? Anything else besides arb's air locker? I would like to eventually install a limited-slip, posi or locker in the rear at least, is there any mechanical/manual lockers out there? ARB's kit is very nice, but I didn't want to get into it that deep with a compressor, air lines and switches etc, I just want something very simple that works
Yeah a Detroit locker for the rear and a winch for the front and you can climb a mountain...literally.
The way a Detroit locker works is it is unlocked until you spin your wheels, then it locks, wheel spin stops, it unlocks.
It is automatic, you do nothing once it is installed.
What type detroit locker will fit the D1? Do you have like a model # or a part #? This sounds pretty interesting..
