DII Oil Leak Repair walkthrough
Old Sep 20, 2010 | 05:12 PM
Boats121's Avatar
Default DII Oil Leak Repair walkthrough
Alright....I have the (what appears to be fairly popular) valve cover oil leak. I was able to tighten the WAY loose outer bolts but cannot figure out how to get to the inner bolts that are positioned under the intake. Is there a simple way to get at them or is that another weekend job? If there is an easy way please help.....I tried the Rave instructions but it was not much help.
Old Sep 20, 2010 | 06:22 PM
NiteTrain's Avatar
you have to loosen intake manifold to get to them..PITA
Old Sep 20, 2010 | 06:28 PM
timdunbar's Avatar
I have the same thing going on, though mine isn't severe yet. When I replace the spark plug wires I am taking off the intake plenum and replacing that gasket, I will also replace the valve cover gaskets and reinstall all the screws with the appropriate size lock-washer and then re-torque to RAVE manual specs. Every fastener should have a locking mechanism of some kind, even if it's just locktite.
zee
Jun 20, 2012 07:50 PM
Ad!
Jan 25, 2012 03:16 PM
losinov
Dec 9, 2010 10:55 PM
flacsrover
Sep 7, 2010 02:05 PM
