DII Reliability Upgrades
Yeah, I'm bored...
Was thinking that for many, reliability is more important than the MPGs, off-roadability or rugged good looks (I have that in abundance!). So what are the top reliability upgrades. So far I came up with:
-Front prop shaft (done it)
-Green coolant (done it)
-Top hat conversion (done it)
-Ultragauge or similar (done it)
-180F thermostat (done it)
-DI tranny pan w/dip stick (done it)
-Airtex water pump
-Electric fan (arguable, but I'm a big fan [pun!] of 3K+ CFM at 0 MPH)
I'd be interested to know what I'm missing. Some of these cost a couple bucks and/or some labor is all. Upgrades that benefit other areas are fine, so long as they improve reliability as well.
-Airtex water pump
coolant filter mod
repalce plastic coolant lines with rubber/similiar material lines
throttlebody coolant bypass (never leak again, and cooler intake charge unless you live north of 45 degrees latitude lol
ditch plastic diff plugs maybe
replace upper coolant t hose where bleeder screw piece is
on
"Oil containing ZDDP, like Rotella 15w40"
_________________________
Unless you don't mind changing camshafts, lifters, rocker arms, etc. frequently.
Does anyone know about, or can anyone suggest, a really good engine upgrade to replace valve train with more modern roller camshaft, using existing camshaft/overhead valve configuration? If that were done, this engine would be comparable with most modern designs.
