DII Rock Slider Plans FOUND
Old Feb 2, 2010 | 08:53 AM
humroot's Avatar
Default DII Rock Slider Plans FOUND
Finally tracked down the plans for some DII rock sliders. The only thing I might try to add is attachment to the frame. I have not built these yet, so I don't know how they fit.
Many folks were asking me to let them know if I found the plans, so here you go:
Attached Thumbnails DII Rock Slider Plans FOUND-rockslider1.jpg   DII Rock Slider Plans FOUND-rockslider2.jpg   DII Rock Slider Plans FOUND-rockslider3.jpg   DII Rock Slider Plans FOUND-rockslider4.jpg
Old Feb 2, 2010 | 08:55 AM
okdiscoguy's Avatar
I know where those came from, I have them too....
Old Feb 2, 2010 | 09:13 AM
humroot's Avatar
You have the plans or the sliders? What do you think of them?
Old Feb 2, 2010 | 09:17 AM
okdiscoguy's Avatar
got the plans a couple of years ago. I gave them to my shop foreman and he is about halfway done with them. Luckily he has not had time to finish. (if he had the spare time, I would be losing money). Don't have them finished, but they look sweet on paper..
Old Feb 2, 2010 | 09:27 AM
I have used a es up like those for 7 plus years, never had a problem or failure of any kind and they can be built for normal wheeling or sever wheeling based on the metal used. I ran 3/16 ths. plate and 2X4 box steel for more H.D protection.
There is no need or benefit to bracing all the way over to the frame.
Old Feb 2, 2010 | 10:57 AM
gowest's Avatar
Nice design, it doesn't seem to show the cut required to make the bend to form fit the sill. That location and size would be important, I guess. I would like to see the press or tool used to then do the bend after the cut is made..That seems to be the challenge to the at home slider project.
I like the smooth edges, that is some nice welding and finishing work.
Old Feb 2, 2010 | 11:07 AM
XCELLER8's Avatar
will these fit a D1 ???
Old Feb 2, 2010 | 01:21 PM
NiteTrain's Avatar
so that design just attaches to the rocker panel? A slider that doesn't attach to the frame is worthless.
Old Feb 2, 2010 | 01:26 PM
gowest's Avatar
What is the upside to having a frame mount?
The style shown will be more than enough protection as it wraps around the sill and bolts through it.
Old Feb 2, 2010 | 01:43 PM
NiteTrain's Avatar
when all the weight of your vehicle is on the side of a big rock the load is transfered to your frame and doesn't collapse the whole side of your vehicle.
