DII Towning Capacity in the real world
Not really an issue - anyone who tows knows enough to tow will make that happen. I can stop my pickup entirely with the brakes on my trailer if I really want to. My normal problem is getting them adjusted DOWN far enough so that I'm not leaving trailer tire on the road (ahhh..the joys of rusty/sticky drums from sitting for months at a time).
So, no surprise, sounds like the same power as towing with my pickup. The numbers are about the same, so I expected that. Just glad to hear from someone else with load distribution/anti sway and know that I'm not going to be white-knuckled the whole way. I don't mind slow too much. I do mind twitchy/weavy/death trap.
If you have been towing for sometime you know how to stop and turn corners.
As long as your trailer and gear weigh less than the tow vehicle it wont push your rear end out from under you in a turn.
Now this is the only reason that you will ever hear me recommend a DII with the SLS (self leveling suspension)
Your butt wont sag, the truck will always side level...until the SLS acts up anyway.
As far as SLS, I'm not sure its applicable with a load distribution hitch. My current pickup has rather soft suspension (its the Ford "4x4 Offroad Package" - meaning they charge you an extra couple grand to put a set of RS5000s, a couple of under trays, a few LESS leaves in the spring pack, and few ugly stickers on the bed). With the load distribution properly adjusted, you're shoving a LOT of weight up front, and the entire truck ends up sitting level. Don't know if you've ever driven anything with a hitch like that - it's magic. You hit a bump and look back and your entire rig is bouncing at the same time - no craziness. All nice and calm and controllable. I never new about that stuff until I got into RVs - everyone uses them for that. Wish I knew that years ago when I was pulling horse trailers.
...so with all the problems I've heard of with SLS, and considering I can manually adjust the hitch to level the truck, it sounds like more trouble than its worth.
Anyway, there are a few of us here that love the SLS, but I think it's really up to personal preference. If they do break, they are relatively easy to replace and you can find replacements for around $100 each online.
Brian
Oh....and, been there done that with the RV. My jack wasn't tall enough. So I found enough cinder blocks/rocks, etc to hold the tongue up at full exension, "lowered" the jack and put some more cinder blocks under it. Then extend - presto.
Whatever works.
Speaking of turbos, there is a video of AMG testing a engine on a dino, no car just the engine, the computer is programmed to run the Nuimburg ring as fast as the car can go and when they do this the turbo on engine heats up and glows like that, its just the most awesome thing you have ever seen...other than a naked woman that is.
