disable reverse beeper?
Old Apr 7, 2010 | 02:13 PM
17outs's Avatar
3rd Gear
Default disable reverse beeper?
So either I have a special disco or its the only one that I have ever seen that has a reverse backup feature (which is entirely possible). As soon as I put the vehicle in reverse it starts beeping. Is this normal or is it only supposed to beep when getting close to something? If so what do I need to change? Thanks.
Old Apr 7, 2010 | 02:20 PM
yloDiscoII's Avatar
What year? If it's a beeping inside, it's a backup sensor that's gone haywire. If it's loud and outside the vehicle someone may have installed the backup beeper to warn kids in the neighborhood...etc,...If nothing else try and locate the beeper and just clip the wires.
....you sure you have a Disco and not a UPS truck right???
GARovee's Avatar
Lose some weight.. Sorry couldn't resist!
Old Apr 7, 2010 | 02:29 PM
17outs's Avatar
3rd Gear
Def outside the vehicle. Sometimes I can hear it over the radio and sometimes not but it starts beeping as soon as its in reverse not even waiting for me to move. Reverse gear but in place beeps. Annoying!
Old Apr 7, 2010 | 05:18 PM
We must know the year of the truck before we can help you.
Old Apr 7, 2010 | 05:25 PM
okdiscoguy's Avatar
Look for a little black module that is stuck by a reverse light, or pull the bulbs for your reverse light and replace the one that looks funny. 2 most common ways to get it to beep in reverse.
Old Apr 7, 2010 | 09:16 PM
Rover Chris's Avatar
if those suggestions dont work have someone set the ebrake and put it in reverse, then listen out back for the beeping sound to pinpoint its location.
Old Apr 7, 2010 | 09:28 PM
bigjerel's Avatar
I don't want to hijack this, but where are the sensors located? When I put mine in reverse I get one long beep that stops after about 10 seconds and from what I read it means it isn't working correctly. It never beeps when I get close to something in reverse either. 03 Disco HSE Thanks for the help. Jere
Old Apr 7, 2010 | 09:40 PM
demonlarry's Avatar
Old Apr 8, 2010 | 07:45 AM
17outs's Avatar
3rd Gear
Mine is a 2000 Disco II. Just got it.
