disable reverse beeper?
Old Apr 8, 2010 | 08:14 AM
I don't think it was ever standard or an option and if your makes a noise from outside, then the previous owner installed an after market alert.
Old Apr 9, 2010 | 06:30 AM
Rovin4life's Avatar
you need to have it hooked up to determine which sensor got damaged.
if it goes off all the time then something is grounding but still get it diagnosed.
Old Apr 9, 2010 | 11:32 AM
bigjerel's Avatar
So if you disconnect one sensor at a time then test the reverse funtion, do you need to jumper the wires when it is disconnected to see if that particular sensor was the issue or leave the thing disconnected?
kevinocall
Sep 26, 2014 12:02 PM
harold.lloyd
Feb 24, 2012 09:12 AM
crownaviation
Sep 7, 2007 02:37 PM
storz
Nov 17, 2006 11:46 AM
oberdahill
Sep 14, 2005 02:28 AM
