disco 1 performance
RE: disco 1 performance
I built a cold air intake, which i think you can buy, I also did an electric fan, I added a flowmaster inb place of the stock muffler and remover the rear resnatior, All this gave it a bit more power and performance, Discos are not racecars but i do understand the need for a lil more power, makes it more reliable to pass on the highway.
There is a computer chip that can be installed, check it out good before you put it in. IF you have any doubt about it don't use it. The other have given good information and the flowmasters sound great. low rumble and a little more kick. Make sure you try to match the air intake flow with the exhaust flow, More air in and unable to get it out increases back pressure on the motor and there is not benefit. Plugs and plug wires are a good thing. (high proformance). Hope it helps. gotta love a rover.
on
1 Post
ORIGINAL: beavis4g63t
i will be installing a set of janspeed headers next week. i will also be installing some high flow cats and possibly build a catback exhaust. i own a 4wd dyno so i will get some before and after numbers to post up.
*researches janspeed*
god damnit! will anyone make headers for left drive Discos? someone should write a letter.
It may be against what everyone may tell me. But i bought a chip from Ebay after weeks of research. I dont know what normal 0-60 is but when i got mine it was at about 12 flat. I'm getting about 6.8 now. I needed a boost for on ramp here in michigan. Most dangerous in the country. Merge lane are just feet to get on. And michigan drivers are very stuborn.
ORIGINAL: 99LRDisc
I have.
