Disco 2 coolant flow direction
Old 07-12-2019, 08:35 PM
Tristan Stumpf's Avatar
Default Disco 2 coolant flow direction
Hey gang,
I am hoping for a little clarification to make sure that my assumptions about how the thermostat works is actually correct.
Coolant flows out from the very hot engine through the radiator top hose, through the radiator.
Then
Flows out through the little bottom hose.
Reaches the thermostat, when that coolant reaches 82c the thermostat will open fully and recirculate through the engine.
Thanks in advance
Old 07-12-2019, 08:55 PM
Jason Feuerstein's Avatar
You got the first part right. Coolant flows out through the top hose.
HOWEVER, because Land Rover really wanted to make sure the heater matrix worked as fast as possible, there are actually three ports on the thermostat. Before the coolant reaches the proper temperature, the thermostat blocks flow from the lower hose and allows flow from the top hose to recirculate back into the engine and through the heater matrix. After the thermostat opens, it blocks flow from the top hose and allows coolant that has flowed through the radiator to circulate to the engine.
Old 07-13-2019, 02:57 AM
acg's Avatar
acg
acg is offline
I do not remember where I got this, but it was from someone in the forum.
Old 07-13-2019, 01:41 PM
JUKE179r's Avatar
Follow the arrows...
The following 2 users liked this post by JUKE179r:
OverRover (07-13-2019), Transfloat (09-21-2024)
Old 09-08-2024, 07:30 PM
Transfloat's Avatar
I would follow the arrows if the resolution on the picture was better
Old 09-08-2024, 09:12 PM
Externet's Avatar
Post
While coolant temperature is low, thermostat is in bypass mode :
Engine outlet-------------->thermostat-------------->coolant pump suction------------> engine block inlet.
After the coolant rises its temperature, thermostat is "open", bypass path gets blocked :
Engine outlet-------------->radiator inlet--------------->radiator outlet---------->coolant pump suction------------>engine block inlet.
Old 09-09-2024, 02:19 AM
JUKE179r's Avatar
Google is your friend.
jastutte (09-10-2024), Transfloat (09-21-2024)
Old 09-10-2024, 11:59 AM
jastutte's Avatar
or, glasses.
losinov
06-14-2022 09:49 PM
cappedup
03-21-2016 02:10 PM
mountainrovernc
Freelander
08-08-2013 01:34 PM
ogden45
01-09-2013 12:42 AM
Snafu / Disco Fries
02-26-2011 08:55 PM
Quick Reply: Disco 2 coolant flow direction
