Freelander Talk about the Land Rover Freelander within.
No coolant flow after change
Old Aug 8, 2013 | 11:32 AM
mountainrovernc's Avatar
Default No coolant flow after change
Just changed coolant on 02 Freelander. Bled air at heater hose according to manual when filling. Not getting coolant through radiator. Top radiator hose very hot - bottom hose cold. Will overheat if I let it run. Tried squeezing lower return hose to work out any air pockets. Possibly air block at thermostat? Any suggestions? Had been parked for about a year with bad transmission - just replaced all solenoids and seems to work now.
Mike
Old Aug 8, 2013 | 01:34 PM
More likely radiator is blocked. Of course, thermostat has to open for major flow. And hoses have to be going to the right place. See attached.
File Type: pdf
jpmiller
Jan 1, 2013 10:05 AM
collin Barrows
Aug 28, 2011 07:13 AM
DiscoBenjamin
Mar 17, 2011 11:30 PM
treant985
Dec 27, 2010 02:51 PM
buick215
Nov 29, 2010 10:10 AM
