Disco 2 / Cranks but won't start
Old Mar 6, 2017 | 10:27 PM
  #21
mollusc's Avatar
I have a spare engine bay fuse box if it comes to that. I believe that it is fully operational.
Old Mar 8, 2017 | 01:02 PM
  #22
Explorer0863's Avatar
Thanks!
Old Mar 8, 2017 | 01:20 PM
  #23
Final report and outcome: the problem was the interior fuse box.
I re-installed the old one that I had removed last year due to the A/C blower issue. Had to reset the alarm and it started on the first attempt. I don't have A/C again, but at least the engine is running fine.
Many thanks to all of you for your help and suggestions.
Old Mar 8, 2017 | 01:39 PM
  #24
LRD2rangel's Avatar
Check a pull a part place for a new interior fuse box. if none are close maybe a member might have one.
Old Mar 8, 2017 | 02:22 PM
  #25
Motorhead1's Avatar
Was it because of rust? Why would the fuse panel go bad? Especially an interior one?
Old Mar 8, 2017 | 03:37 PM
  #26
I don't know for sure, but I don't think that it was rust. I opened it and I saw no rust, but I noticed that one of the soldered "things" on the electronic board looked burned.
If you Google search "Land Rover Discovery 2 fuse box", you'll find a lot of people having problems with the fuse box; especially with fuses 6 and/or 7 for the A/C blower motor.
It was another forum member that posted the instructions on how to diagnose the issue and check for the proper current going from the fuse box to the coil packs.
Old Mar 8, 2017 | 03:56 PM
  #27
shanechevelle's Avatar
I might be heading to the UPULLIT Friday or Saturday, I can look for a fuse box.
Old Mar 8, 2017 | 05:17 PM
  #28
Motorhead1's Avatar
Thanks for the update. I will google it
Old Mar 9, 2017 | 02:38 PM
  #29
Best4x4's Avatar
Make sure you get the proper interior fuse block. 99-02 is not the same as 03-04.
Old Apr 25, 2017 | 11:05 AM
  #30
Homewreckerz's Avatar
4th Gear
Default Fuse box underneath hood?
Originally Posted by zuke
For what its worth I purchased a Disco with the same intermittant starting problems about a year ago. The previous owner gave up trying to fix it.
Going through his records I saw that the ECU had been swapped out 2 years before at a dealership. Whoever replaced it did not put the plugs back in the correct order meaning #1, then #2 etc. They did the ends then worked in to the middle.
Anyway the middle plug would ocassionaly fault after hitting a bump then no start. Next day it would fire up and go for a week. It took me 3 weeks to figure this out. Pulled all 6 out then put them in per the manual. All is good now.
-I'm having the same intermittent starting problem. Are you talking about the fuse box from the ecu under the hood? Would plug #1 or #6 be toward the front of the truck? Also, could you post the connection procedure from he manual? Thanks, Homewreckersz
