Disco 2 Dash lighting, Parkng lights not workin
Old Oct 17, 2008 | 11:20 AM
toolish1's Avatar
3rd Gear
Default Disco 2 Dash lighting, Parkng lights not workin
I have a 99 Disco 2. All of the sudden the lights on my dash, hvac controls, shift indicator, parking lights, don't work. I've checked ALL fuses inside and out and they're all fine. Passenger side parking indicator will work when i arm the alarm but not when i turn the parking lights on. Any one know WTF to do?
Old Oct 17, 2008 | 05:07 PM
Default RE: Disco 2 Dash lighting, Parkng lights not workin
Do any of your tail light lens have moisture inside them?
Do ALL of your brake lights work?
Old Oct 17, 2008 | 07:03 PM
toolish1's Avatar
3rd Gear
Yes both brake lights work, no moisture, replaced bulbs, checked fuses, etc. Its only the brake(tail light) parking light(inside headlight), yellow turn signal light(next to headlight) all non-working lights on the passenger side, dash,hvac, shift indicator also don't work? Thanks for your reply, any thoughts?
Old Oct 17, 2008 | 07:09 PM
How about the high mounted brake light in the middle of the cargo door?
I have heard of this before but the fix was never posted.
So if your highmount brake light is working then I have no clue as to what it could be.
Old Oct 17, 2008 | 11:25 PM
tacomatech's Avatar
Check your dimmer switch and light switch(stalk). Just a thought.....
booper169
Mar 20, 2019 09:37 PM
rchrd0413
Mar 7, 2014 06:03 AM
Pik
Dec 27, 2012 09:25 PM
Silver Fox 40
Oct 31, 2010 07:48 PM
umoms
Apr 3, 2008 06:22 PM
