Disco 2 foglight problem I can't figure out
Well I have a 99 disco 2 and the factory foglights where working fine then one day I saw one wasn't working so I put a bulb in it and it still didn't so I took the bulb out of the other foglight to see if it was the bulb and it still didn't work so I bought two new bulbs for the foglights just to see if I could get one of them working again then figure out the problem with the other well now neither foglights work with two new bulbs. So I check output of the foglights with a multimeter and sure enough both say they have 12volts. So whatsgoing on thats allI thought there was to it????
RE: Disco 2 foglight problem I can't figure out
I also have a '99 dII and my fog lights will come on with or without my high beams being on. Is the indicator light on the switch lighting up? If it is, check the fuses first. Second, check and clean the bulb connection, and the actual light connectors under the bumper.
Well I was guessing if I check the output with a multimeter and was getting 12 volts then everything to that point had to be good such as fuses, low beam and foglights all on. I did check fuses and everything before the multimeter though and I had low beams on and the green light on the fog light switch is on but still nofoglights. I was wondering how does the ground work because with a multimeter I ground the lights on the frame and I just check to see if it is getting voltage and they are so I was guessing my only problem would be ground so how are they grounded?
