3 trips to the dealership...still can't figure it out
Old Nov 19, 2010 | 06:36 AM
azaky's Avatar
4wd High
Default 3 trips to the dealership...still can't figure it out
Problem... When I turn I hear grinding. Thought it was the traction control but no faults found. Thinking it might have something to due with the rod mods, because I hear it more in offroad mode while turning..
They can't see any issue? Any ideas?
Old Nov 20, 2010 | 02:03 PM
Rovin4life's Avatar
you mean the grinding from hitting the bump stops. otherwise put some grease on the bump stops on the front.
Old Nov 21, 2010 | 01:22 AM
Count Laszlo's Avatar
Usually this sound is from the rear diff if you have locking diff, LSD... you'll get an odd grinding/roar sound. Have they checked, do you have a locking diff?
Old Nov 22, 2010 | 02:33 PM
azaky's Avatar
4wd High
I don't think I have the rear diff. But I would hear that in the front wheel areas?
Old Nov 27, 2010 | 07:31 PM
Nightcrawler's Avatar
Wheel bearings?
Old Nov 29, 2010 | 08:24 PM
safarisam's Avatar
Can you feel the car bump when you hear the noise?
Old Nov 29, 2010 | 08:48 PM
dragan's Avatar
i have similar problem for a wile.I replace tire and noise is gone.
You may need rotate tire for a start.
mwkoh
Jul 24, 2014 12:42 PM
rover newb
May 12, 2011 05:42 PM
tee51397
Apr 29, 2008 07:09 PM
95DiscoSE7bullitt
Aug 22, 2007 05:59 PM
