Disco 2 help please
I have a couple things i need help with. My 2000 disco 2 rear windows have stoped working, along with the rear sunroof. I did some research, but just wanted to get some clarification. Dose this year disco have a window lift ecu AND a body control module? or just one of the 2? And am i on the right track to fixing this issue by replacing one of those (still not 100% on which one)?
Second little problem is my passenger front door lock stoped working aswell. I researched that aswell and found that it's most likely the door lock actuator. Would that be correct or is there anything else i should look into?
Thanks in advance!
Thanks in advance!
You have a sun roof Ecu and a BECU, D2's don't have window ECU's
http://www.roverlandparts.com/electr...lunitsecu.aspx
whurst79
Jan 28, 2013 09:24 PM
