Disco 2 HomeMade Roof Rack build!
Old Jul 26, 2020 | 09:18 AM
  #51
Fastercat's Avatar
Nice to hear it’s still working for you
Old Aug 22, 2020 | 11:58 PM
  #52
Roverman2004's Avatar
4th Gear
Originally Posted by dparham
total was about $50 in 10x1/2 EMT and 10x3/4 EMT have enough left could build almost another or at least most of one! $15 in bar stock
another $5 in 3/8 bolts
$4x8 for ***** and washers ($32 )
paint was about $5 a can.. 5 cans... maybe could ave had it powder coated but this paint is really good! shown earlier but cans drip so I used rubber gloves lol
misc welding or brazing rod, and I had to fill my small portable 02 and acetylene tanks.. but have plenty left so Im not factoring that in.... rod maybe 10 rods of 1/8"
and for the Finally!
well first formal fitting.. lol
from a distance off a person would think you spent big money on that rack. It looks damn good. How rugged is it? How's its strength? When you walk on it does it bend?
Old Aug 23, 2020 | 02:33 AM
  #53
The Deputy's Avatar
A nice touch would have been...adding some flat stock between down riggers/rack supports...for mounting a shovel or sand tracks. Granted, maybe not needed in your case...but others that might be following along and considering a duplicate. Great looking rack overall...and glad to hear she's still holding up...even under assault.
And please don't take my constructive criticism personally...hell, l've had my Defender's rack on and off four times...and l'm still not a hundred percent sure it's done...lol. Everything, is work in progress, when you build it yourself.
And like the Friendly Giant use to say..."look up, look waaaay up"...for that next trip through a parking garage. Okay, l might be dating myself here...lol. Old childrens program from the sixties.
Old Aug 23, 2020 | 08:01 AM
  #54
dparham's Avatar
hahaha well I agree! It didn't sound like criticism just sounded like options! After all I did make it custom to put whatever I needed on it! I did have plans to do some more to it.. its held up well... I think a new one id use 1 size larger eat and it would be rock solid! I could easily walk on the sides and the front but the basket Id not do as its kind of close to hood... design 2 would be to make it a slight bit shallower and add a low rail over top basket.... maybe add that or make a clamp on rail in case I needed put something on tall... right now I can put 4x8 sheet plywood and more! I can easy hole 4 sheets as I did and u can easily load it up! anyway its not very flexible but id not stand in center of rack and jump up and down it may flex a little... I have bracing around to compensate for that though.. I wanted to add all kinds of goodies to it but if had some engine and suspension work I've had to do first then have started making guitars again and its taking up a good potion of my time!also having some paint fade so need to address that too!
Old Aug 24, 2020 | 04:59 AM
  #55
SundayFunday's Avatar
That is impressive. Very nice.
& bike framesmith as well...
Were you making only recumbents?
Or are you building for Hetchins..!?
Old Aug 24, 2020 | 08:50 AM
  #56
dparham's Avatar
THANKSI I made some recumbents and other bike builds too my main building is custom guitars ...
Old Aug 25, 2020 | 07:14 PM
  #57
merebel's Avatar
Looks great gives me ideas. Wondering about using 1” tubing and how strong that might be over all?
Old Aug 25, 2020 | 07:36 PM
  #58
MrHSE7's Avatar
Awesome roof rack dparham. Glad to have found this thread.
Old Aug 25, 2020 | 07:53 PM
  #59
dparham's Avatar
i think i would consider using 1” next time only because it looks beefier lol but this works fine u less u want to put an atv on top or really load it up! U could do 1” around bottom for strength then 7/8” for the rest for weight .. also remember the gutter channel will also be taking the weight .. just my observation
Old Aug 25, 2020 | 08:00 PM
  #60
merebel's Avatar
with yours are you able to stand on it with little issue?
