disco 2 no tach
Old May 26, 2020 | 06:17 PM
bulletbirdman's Avatar
3rd Gear
Default disco 2 no tach
Guys got a 2001 can't get the tach to work engine runs great so CPK is working any ideas?
Old May 26, 2020 | 06:57 PM
greisinb's Avatar
The PWM signal for tachometer is on ECU's connector C0637 pin 17 (white/grey wire) if that's what you need. Its a 12V signal, 4 pulses per revolution. So that's at least a place to start looking if you've got a signal or if its an issue inside of the dash.
Old May 27, 2020 | 09:32 AM
3rd Gear
thanks
Old May 27, 2020 | 12:34 PM
Jason Feuerstein's Avatar
If you have an ODB2 reader you can pull tach data from the ECU. If you can get the RPM from the port but it's still not showing, it's most likely going to be an issue with the dash.
RoverJayTX
Apr 5, 2018 04:49 AM
Rover2013
Jun 2, 2013 08:40 PM
John Garcia
Feb 13, 2012 06:09 PM
tornado_735
Jul 22, 2010 05:53 PM
dukhooked
Oct 24, 2005 07:00 AM
