Disco 2 No turn signals
My right turn signal went out a couple months ago. A few turns it had flashed rapidly and then just completely quit. I swapped the left and right relay and the problem followed the relay. A local parts place (Pep Boys, Advance Auto, I forget which one) had a relay in stock for $2-3. Odd that both of yours don’t work. The relay would be a good place to start assuming the bulbs are good.
The stalk he refers to is the signal light arm/lever on the left side of the steering column. The contacts in there can become worn, corroded or burnt, and some of the lever functions will not work. I just replaced mine as my taillights were not working. I bought a used one from Shiyco Parts of Myrtle Beach (thanks Wilson) (Shiycoparts@hotmail.com), then pulled the one I had apart and cleaned the contacts, and it now works again, so I have a spare.
Pretty straight forward removal, once it is removed from the column which is pretty easy, and it takes just a little bit of carefully prying to unsnap the housing at the base of the lever to open up the inside where the contacts are. Open it where you can catch any parts that may fall out, as there are one or two that could drop out on you. I found some black contact points that I cleaned with emery cloth, so they shined again. It was good to have two to look at, I ended up taking my new used one apart to see how all the parts went back together to get my original one together again. Now both test good. I will see if I can find the link to the instructions I used, they were pretty good.
The BCU drives the IDM on the back of the fuse panel, which operates either the LH or RH direction indicator relays. These drive the lights. Lots of connections. Those tiny numbers cross you over to the electrical library connector lists, which have photos of locations. See attached diagram. Don't think there is a conventional "thermal flasher" module.
You should be able to put a ground on pin C0660-6 or C0663-2 at the BCU and simulate the input from the stalk.
Would think if hazards work that problem remains in the stalk or ground for it.
