Disco 2 quits running
This morning, the Rover died after traveling @ 7 miles on highway, died while waiting for light to change a few min later. We had it towed to a shop down the street, got it off the flatbed, they turned the key and it fired right up. We drove it home 7 miles on the highway and 2 miles stop and go to our house, no problem. After 15 min, tried to start it to go to grocery store, turns over but, again will not start. Fuel pump or crank shaft sensor? How would I check either item? Or could it be something else. It doesn't have any hesitation prior to stalling.
Bad crank sensor. No way to check it, either it works or it doesnt.
www.atlanticbritish.com
When it gets hot it will fail, eventually it will fail completly.
pull it out and take a look at it. If it's covered in shavings, oil or looks heat scorchedI would just replace it. If it's never been replaced I would do it anyways, they tend to fail. They are about $80 at the dealer usually. You can check it if you're good with a volt meter, it should fluctuate if it's working.
