Disco 2 Temps Ok?
Old Aug 12, 2024 | 03:24 PM
ACKD2's Avatar
4th Gear
Default Disco 2 Temps Ok?
Hello,
I recently purchased an '04 Disco 2 with a recently replaced engine and new head gaskets. The truck runs well and has the factory cooling system, but runs between 200-211 degrees while driving and drops to about 195 while idling. I have ordered an inline thermostat to help the truck run cooler, but are these temps a concern to drive with for the time being? I have heard very mixed opinions.
Old Aug 12, 2024 | 03:58 PM
Richard Gallant's Avatar
@ACKD2 The temps are ok,they are actually what 04's were set to run at. But the problem is if you have a cooling issue. Overheat is 244F, so the higher your running temp the less head room you have if the cooling system has an issue
Old Aug 12, 2024 | 06:24 PM
Extinct's Avatar
It should be ok until you get the inline just keep an eye on it.
arains44
Jul 24, 2022 01:03 PM
Brandon318
May 31, 2019 10:09 AM
Luckyjayb
Feb 19, 2017 04:36 PM
Freedom38
Nov 4, 2015 09:43 AM
driftology
Jul 10, 2014 06:40 AM
