Disco 2 Tow Hitch install?
Old Mar 7, 2018 | 07:16 AM
oaty's Avatar
Default Disco 2 Tow Hitch install?
Got a Curt Tow Hitch at "Pull-A-Part" yesterday. The two (2) bolts next to the insert are very tight and still have a gap. These are the two bolts that go into the rear bumper. They are tight but not fully seating into frame. The bolts are the same as pulled from the donor Disco 2. The bolts appear to have had loctite on them. Anyone have comments or instructions on a tow hitch install. I will see if I can take pictures.
Got the tow hitch for $28 bucks.
Old Mar 7, 2018 | 08:03 AM
Sixpack577's Avatar
Did you clean/wire brush all the old thread lock out of the bolt threads?
Are the threaded bolt holes clean?
Old Mar 7, 2018 | 08:10 AM
OverRover's Avatar
In case you don't have the basic install sheet from Curt
> https://assets.curtmfg.com/masterlib..._13455_INS.PDF
Old Mar 7, 2018 | 08:36 AM
oaty's Avatar
Thanks guys. There is some thread lock on the bolt. I sprayed WD40 in the hole and even sprayed high pressure water in the hole to flush out. I did not try the wire brush. I will try when home.
Old Mar 8, 2018 | 06:07 AM
oaty's Avatar
Default Fixed tow hitch
Thanks again. Swapped bolts, one was cross threaded from all the tries to mount. Had lots of grime in hole. Had more thread lock than perceived. Got hitch mounted and snug.
Lesson learned. Don't not get in a hurry when you need to do it right (the first time).
Cheers
carlitonsky
Jun 13, 2009 11:33 PM
NornIron
Jun 26, 2008 12:47 AM
mitsi88
Jun 3, 2008 05:47 PM
S4poor
Feb 10, 2008 10:15 AM
