Disco 2 Vibration under power btwn 35-50 mph
The same problem...
check the rear rotor flex. its a rubber coupling between the rear driveshaft and the differential.
Also, this my seem like im crazy, but Check your tires as well. Check to see if you have thrown a wheel weight. Also check them for water ingress. Remove the valve stems and see if you get water spray coming out. I know it sounds wierd, but my last set of tires had water in them and caused a similar vibration. Also, there should also be a grease plug on the rear u joint and slip shaft. Lube those up.
I am assuming you have modified or replaced your front driveshaft?
I have the same issue with my discovery II I replace the front drive shaft for a heavy duty one but still is shaking 60-80 km/h
Some help??
