disco 2000 aux switches/connections
Old Nov 6, 2016 | 07:50 PM
JUKE179r's Avatar
Thanks to PaulMc for the info!
While turned on, my aftermarket fog lights have been erratic turning on and off by themselves and now they don't come on at all.
I'm getting power to the switch and the filament in the foglight bulbs are both in tact. I'll have to dig into the aux lighting kit relay ECU and wiring to see what the deeper problem is.
Old Mar 16, 2017 | 06:25 AM
dwatterson1's Avatar
can the front fog light wiring be used instead to power safari light 5000
Old Mar 16, 2017 | 07:51 PM
zoltan7's Avatar
Yes sir.
I run a 100w hella 4000 off each fog light wiring. Your fog fuses are like maybe 20a. That means you can safely go up to 240ish watts. So be careful if you keep the factory fogs too since they're 55w each. Plus the wire is kinda small (18 gauge maybe) which is pushing it for anything past 200w.
ebg18t
Apr 6, 2012 04:35 PM
co556guy
Apr 4, 2009 01:47 PM
Flipper
Sep 7, 2008 09:46 PM
Chrisinhouston
Mar 2, 2008 05:21 PM
rovernbama
May 15, 2006 03:03 PM
