Disco 2000 rear suspension - air - few questions please answer...
couple of questions, related to the sinking in the rear suspension, when the car was on it took forever but it did raise back to normal height, then when I turn the car off it sometimes does or doesn't sink again, it is on the drivers side and not really the passenger side, but anyway I was looking underneath the car and noticed that there is a small leak of a yellow colored fluid, located after the catalyic converter, in the middle, towards the back?? What could this be, never noticed it before...also I am worried that if I do buy new air suspension bags it still will not raise, is there a way to find out if the compressor is the problem or just the bags??? It is sitting right now in the driveway, should I raise the back of it is ok sitting sunk in the back?? Is it safe to drive a short distance??
Thanks for all your help.
Hi, I am having the same problem with my Series II 2000. The rear suspension sinks sometimes when parked. Here's the cause and effect: When I sit on the back bumper while getting ready for a bike ride, I'll come back from the ride and it's slumping. When put in gear after starting it'll pump itself back up in about 2 or 3 minutes. What do I need to do (other than lose weight)?
Many thanks
Many thanks
glazener24
08-02-2008 07:53 AM
