Disco Guru's HELP..3 amigo issues!!!!
Old Feb 8, 2010 | 05:46 PM
bmccool21's Avatar
3rd Gear
Default Disco Guru's HELP..3 amigo issues!!!!
hey guys im having the 3 amigo problems on my 04 disco and ive searched and searched and tried everything and i cant get them away!!!ive tried the following:
checked voltage at slabs ecu for each wss
shuttle valve repair kit
used modulator
another slabs unit from roverlandparts.com
flushed brakes
Thier not staying on all the time but keep comming on and its throwing codes for: modulator, module and short at one of the sensors!
any help is awesome guys!!!!
Edit: just got the codes from the shop:
pump failure 1
pump failure 3
shuttle valve switch
Old Feb 8, 2010 | 08:20 PM
brooksa's Avatar
Did you follow the ABS "how to" fix as listed in sticky?
Old Feb 8, 2010 | 09:51 PM
Scott R's Avatar
Without knowing the codes you're just going to be throwing money at it. Find someone near you with a reader and get it sorted correctly.
Old Feb 8, 2010 | 10:13 PM
meltdowndave's Avatar
For the price of two-three trips to have your codes read at the dealership, you can pick up an ABS Amigo and read them yourself.
There are also a couple floating around for rent, too.
As mentioned above, you're wasting money until you have the hard info.
Old Feb 9, 2010 | 06:03 AM
bmccool21's Avatar
3rd Gear
the shop that got the codes has the exact name of the codes i will get them today!
Old Feb 9, 2010 | 08:24 AM
hilltoppersx's Avatar
ABS codes, ABS codes, ABS codes...
Old Feb 9, 2010 | 08:41 AM
bmccool21's Avatar
3rd Gear
today im going to scope the wss and see how the waveforms look and also do the tests on the modulator in sticky
rit1267
Apr 12, 2015 07:16 PM
HOSER
Apr 16, 2012 04:18 PM
DiscoIIBrandon
Jul 13, 2011 09:25 PM
0304Disco
Mar 31, 2011 04:42 PM
mordor110
Dec 10, 2007 09:50 PM
