Are Disco I and II exhaust manifolds the same?
Old Apr 30, 2012 | 09:44 AM
hhalimi's Avatar
Default Are Disco I and II exhaust manifolds the same?
I have broken studs in my exhaust manifold, I am getting sick of the shop keep calling me and raising the price for fixing what they broke.
I was wondering if Disco I and II exhaust manifolds are the same? I just want to buy the manifolds and do the job myself and don't want to deal with the shop anymore.
Old Apr 30, 2012 | 10:08 AM
jafir's Avatar
Old Apr 30, 2012 | 10:18 AM
hhalimi's Avatar
Thanks for the quick reply, do I need to change the manifold to block gasket or I can use the old ones?
Old Apr 30, 2012 | 11:01 AM
jafir's Avatar
I would replace them, because they seem to be pretty cheap.
Old Apr 30, 2012 | 11:32 AM
Discovery SE7's Avatar
The gaskets and the bolts are supposed to be replaced anytime they are separated.
Old Apr 30, 2012 | 11:35 AM
hhalimi's Avatar
I can't get them locally, so I have to order them online. And I was thinking of getting used ones, not new manifolds. New ones are too expensive.
Old Apr 30, 2012 | 11:43 AM
jafir's Avatar
You can probably order gaskets locally from autozone, part number MS19613, but they are way over priced in that brand... about $40.
I wouldn't pay for NEW manifolds either. way too spendy for me. I was just using that link as way to see what it fits.
Old Apr 30, 2012 | 11:45 AM
hhalimi's Avatar
Even the manifold bolts?
Old Apr 30, 2012 | 12:06 PM
Exhaust manifold = Yes.
Upper and Lower Inlet manifolds = No.
Also make sure you have a good torque wrench that measures in ft lbs. I have taken these things apart and had them not torqued properly, which may have contributed to other problems developing.
Old Apr 30, 2012 | 01:36 PM
hhalimi's Avatar
Thank you man for the help.
I just had a little exhuast leak when car was cold, which I tried to fix and now this mess. I should have listened to spike
