Disco I Rear Power Window?
Old Oct 4, 2009 | 03:29 AM
vips_one's Avatar
3rd Gear
Cool Disco I Rear Power Window?
I recently bought a 96' disco I...
The two rear windows didn't work, and he (last owner) didn't want to give me details on the issue. I just removed one of the rear door panel and realize he fitted some clips on the door to keep the window from going down...
From outside the regulator seems to be fine, so it could be the motor right? I mean if the motor failed, would it still move which would explain why he had to put clips?
It could be an electrical fault, but then he wouldn't have needed to clip the window in position since electrical failure would keep it blocked...
Thanks in advance for input!!
Old Oct 4, 2009 | 06:14 AM
He may have just made this problem 1000x's worse for you.
It is common for the window lift ECU's circuit board to get small cracks around the solder joints and then the windows will not work.
Remove the circuit board, resolder the joints, replace circuit board, windows work.
30 min DIY if you know how to solder a circuit board.
www.atlanticbritish.com sells a window lift ECU repair kit for $15 or so, it even comes with instructions.
So depending on what the other guy did to the windows will determine what you need to do to fix the windows.
Did he just push the glass all the way up and then fasten it in place?
Or did he totally jack up everything?
Thats what you will need to figure out.
Old Oct 4, 2009 | 12:09 PM
vips_one's Avatar
3rd Gear
Default Haaaaaaaaaaa
Heyyyy I think you're really onto something here... When I dissembled the window switches panel there was (un-explainable) crazy glue all over the panel so what you said about the window ECU makes a loooot of sense... Like you said hopefully it's not beyond repair point haha!
Thanks a lot for the very useful input!!
Old Oct 5, 2009 | 08:41 AM
XCELLER8's Avatar
Cool
damn those PO s again ....
we've all gone (going) through it....good luck !!
Old Oct 6, 2009 | 08:52 AM
vips_one's Avatar
3rd Gear
Default Xceller8?
By the way... soory for going off topic, but Xceller8, very nice mods list you got yourself! yout ought to be proud for changing all those things that big time modders sometimes overlook...
Keep it up, and thanks for Xtra input!
Old Oct 6, 2009 | 10:44 AM
toonew2know's Avatar
Default windows
Same problem on my '94. I tested all the switches, motor, etc, finally just rolled it mannually and unpluged the switches... The ECU's are where?
Old Oct 6, 2009 | 08:20 PM
The ECU for the windows is behind the glove box.
Old Oct 6, 2009 | 11:01 PM
Default windows
thanks
twoxred
Oct 4, 2021 07:07 AM
slanginsanjuan
May 14, 2012 07:55 AM
mmcc100
Jul 8, 2009 04:36 PM
ljdiscovery
May 22, 2008 10:30 AM
bigfun
Mar 14, 2008 09:27 PM
