Disco II Carpet Replacement
Old Aug 23, 2010 | 10:46 AM
joatman's Avatar
Default Disco II Carpet Replacement
Anyone pulled their stock carpet and replaced with a rubber liner?
Results? Good, bad, ugly?
If you did and are happy withe the outcome, can you share? I'm thinking about the swap, but don't know where to begin looking for material, or what is the best material to use in the first place.
Thanks!
Old Aug 23, 2010 | 11:35 AM
sloan74's Avatar
If your gonna pull the carpet, I would use a good Rhino Liner (like spraying the inside of a truck bed). That's the way to go.
http://www.rhinolinings.com/applications/trucks~jeeps
We did that in Jeeps. But we also did serious off roading. hehe
You would have to pull the seats also. Clean/prep/tape everything real good, etc.
It's not that much work, is cheap, and would be a killer mod if you ask me.
________
Streaming Xxx Videos
Old Aug 23, 2010 | 12:11 PM
Spencerfitch's Avatar
Hurculiner.
Old Aug 23, 2010 | 12:47 PM
sloan74's Avatar
yup hurc works great too.
________
Yamaha ya-3
Old Aug 23, 2010 | 01:21 PM
joatman's Avatar
I wasn't even thinking about a spray in, but that's an idea. I had Rhino Lined an old Land Cruiser I used to own. Outcome was great, but plugging all of the holes, then having to go back and run a tap through a bunch of them was a pain. Also had to go back and shave down some mount points so everything would go back together as it should.
I was thinking of just going with a rubber mat, but now I'll have to do some serious thinking.
-Aaron
Old Aug 23, 2010 | 01:58 PM
sito007's Avatar
whats the cost of doing this to a disco?
Old Aug 23, 2010 | 02:45 PM
sloan74's Avatar
$80-100+- bucks for a gallon I think last time I priced it. If you find any rust you will need to sand/air grind it off. I would Simple Green (spray cleaner) everything real good also before coating.
The prep work is where you spend all the time. Applying the liner is easy.
________
MONTANA DISPENSARY
swampthing
Jan 12, 2020 02:23 PM
digitalb3
May 2, 2013 11:01 AM
gulfcoastgorilla
Dec 13, 2012 09:41 AM
discoxd
Jun 29, 2009 07:29 AM
