disco II drain plug. Is this it
Old Jun 26, 2010 | 04:29 PM
mvjimenez's Avatar
4wd High
Default disco II drain plug. Is this it
Trying to flush the rad can't find it. Rave manual instructs as follows,
Drain and refill
$% 26.10.01
WARNING: Since injury such as scalding could
be caused by escaping steam or coolant, do not
remove the filler cap from the coolant expansion
tank while the system is hot.
Drain
1.
Visually check engine and cooling system for
signs of coolant leaks.
2.
Examine hoses for signs of cracking, distortion
and security of connections.
3.
Position drain tray to collect coolant.
4.
Remove expansion tank filler cap.
LH side
RH side
5.
Remove drain plugs from LH and RH sides of
cylinder block and allow cooling system to
drain.
6.
Disconnect bottom hose from radiator and
allow cooling system to drain.
7.
Disconnect top hose from thermostat and
position open end of hose below level of
coolant pump inlet, to allow coolant to drain
from the system.
Refill
1.
Flush system with water under low pressure.
Do not use water under high pressure as it
could damage the radiator.
2.
Apply Loctite 577 to cylinder block drain
plugs.Fit drain plugs to cylinder block and
tighten to 30 Nm (22 lbf.ft).
3. Connect bott
where exactly are the plugs?
Old Jun 26, 2010 | 05:31 PM
ljdiscovery's Avatar
don' worry about the drain plugs, just rinse the block through the hoses, disconnected from the radiator and that should suffice. The drain plugs are a pain to get to, take out and put back in. phil
Old Jun 26, 2010 | 06:01 PM
mvjimenez's Avatar
4wd High
thanks will try tonite
Old Jun 26, 2010 | 07:36 PM
Yup, just remove the lower radiator hose.
focusontheworld
Nov 13, 2007 10:26 AM
mburnett
May 28, 2007 09:18 PM
jacksyachts
May 2, 2007 11:49 AM
jwmstang
Apr 15, 2007 06:05 PM
anonimaus
May 1, 2005 05:01 AM
