Disco II engine install
Hi
I have a 99 disco II with a blown motor so I am in the final stages of installing a motor out of a 98 disco I... problem seems to be the engine is sitting to high now?
Need some advice here...are the motors not the same? Also for installing the converter bolts do I need to remove the engine mounts and drop the motor again to reinstall them?
I did not remove the transmission, only the motor. There are two plugs on each side of the transmission to access the flywheel and converter bolts....maybe a couples of inches large.
The motor is bolted up all around the bellhousing. But I'm thinking that the two motors may be a bit different from each other or the motor-mount brackets on the frame are different.
According to RockAuto and comparing the old mounts vs the ones from the parts truck they are the same. Not sure whats wrong, just that the engine seems to be contacting the hood when trying to close it.
So far the wiring is identical except one sensor near the water pump.
Oh that reminds me...there is two greens wires, one each from the o2 sensor harness on each side...Anyone know where these bolt on to?
The gems and the boshe have different Ckps mount and the knock sensors are also a different style. Both can be worked around
All the sensors seem to be the same with only a sensor on the timing cover being slightly different.
But I'm about ready to give up and scrap this thing. Still have no idea what the two green wires are for and now I have to replace the timing cover. I have tomorrow left to get it running and to the garage for a safety inspection or not at all.
I cracked the timing cover tonight installing a line from the rad to just beside the oil filter. I'm going to use the cover from the blown motor and some silicon sealer in place of the gasket.
If I can't get it running tomorrow and brakes done it's off the to scrap yard.
I don't want to tell you what to do, but sometimes you have to slow down to go fast. When you try to get things done fast, you can make mistakes. Then those mistakes cost you more time and money. We've all been there. So I don't mean to sound like a jerk, which is probably the last thing you need when you're frustrated.
When I find myself doing more harm than good, I take a step back and try to relax. Maybe take the rest of the night off. Then when you go back to it, you can try to look at it in a different way. Most of the time it makes things go smoother.
I hope you get through it. It's always worth it when you get to drive it again!
