Disco II on an engine stand
Old Dec 15, 2013 | 06:27 PM
Charlie_V's Avatar
Default Disco II on an engine stand
I searched the forums and couldn't find the size of my transmission bolts to get longer ones to fit in my Craigslist engine stand. The stand arms have about 1 1/2 inch collars.
So that no one else will have to hit an miss it like I did, the correct size is 3/8-16 x 3 inches. Four of them. T8.
Unfortunately the stand I have does not quite reach the fourth location (bottom most hole on the block) so I had to put it on a higher bolt hole. That makes me nervous so I put a strap under the crank pulley and lifted it slightly to take weight off of the bolts until I remove the heads for planing.
Best,
Charlie V
Old Dec 15, 2013 | 06:30 PM
Charlie_V's Avatar
And if you are reading this, you're probably know what engine I have. But just in case: 4.0 Bosch.
Old Sep 5, 2016 | 04:35 PM
DiscoBuckeye's Avatar
I had heard 400lbs so just in case I went with 1000lbs capacity
Thanks for the quick responses
abran
Sep 5, 2016 06:40 PM
LandRoverSE
Nov 3, 2012 06:03 PM
Randy Lover
Off Topic
38
Oct 13, 2008 09:23 AM
BADBUZzZzZz
Mar 13, 2008 05:06 PM
jkeving
Jan 19, 2008 08:06 PM
