Disco II fuel issues
I have a 97 se7. I have replaced the fuel pump and filter, but I still can't get it to fire. It will run with starter fluid. It wants to go, but won't stay running. I was driving it, when it shut off on me. I have also replaced the CPS sensor... Anyone have any ideas?
Your injectors are not firing on the D1.
Double check the CPS.
Pull out the ECU and check the ECU for corrosion.
Unplug and plug in all the plugs you can find.
Also if you parked out side Woodrats or squirrels can eat thru only one wire
and kill the truck.
but you were driving it.
Fuel pump may not be turning.
Check the inertia sensor by pressing it in.
and kill the truck.
That does sound a lot like a fuel pump not holding pressure (you may have a leak somewhere else in the fuel system causing the pressure leak but you will usually see fuel leaking if that is the case). The first time you are cranking on the engine, it is building up pressure in the fuel system that leaked out. The second time you try and start it, it works because the first set of cranks built up the pressure it needs to start.
You need to do a fuel pressure test or you can try to confirm the bad pump by turning the key to the on position (don't try and start) wait 5-10 seconds then turn the key back to the off position. Then do that again 1-2 more times. On the 3rd or 4th time try and start the truck. If it fires right up then your pump is going bad.
JumPeR04
Apr 7, 2011 09:52 PM
JumPeR04
Apr 1, 2011 04:15 PM
