fuel issues?
Old Jun 19, 2010 | 08:15 AM
musickjr's Avatar
Default fuel issues?
Hello ou there is Rover land. I have an issue that I was hoping someone could help with.
I have a 1999 discovery 1. about 120000 miles. I can crank up the truck, and it will idle great, no problems. I drive for about 100feet, and it dies, and then doesnt want to crank up for about an hour. any suggestions where I might start, or what to look for?
Thanks, Mike
Old Jun 19, 2010 | 08:51 AM
vandev's Avatar
Default maybe
could be your crank sensor going bad....
Old Jun 19, 2010 | 08:54 AM
musickjr's Avatar
I replaced the crank sensor, and the cam shaft sensor, and the fuel pump recenty.
Old Jun 19, 2010 | 09:08 AM
kenk's Avatar
Did you replace the fuel filter also? Let it sit, so it will start, then run it 'til it dies. Then turn the key to the run position and check the fuel pressure at the rail( a round tire air pressure gauge works great, not the pop-out stick type). Could be an alarm issue, immobilising the vehicle. Could be the pump not getting power( relay, short in the wiring,etc)
Old Jun 19, 2010 | 09:13 AM
musickjr's Avatar
Oddly I replaced the pump, but could get one of the ends loose on the filter, so no, it didnt get replaced. i do have pressure at the valve, good pressure. I can also hear the pump running when its quiet outside.
The wierd thing is that it will normally crank up, its just when i drive it that it dies.
Old Jun 19, 2010 | 10:30 AM
Replace that filter before you start plugging up your injectors.
Did you install a new Rover pump, used or after market?
Old Jun 19, 2010 | 11:05 AM
musickjr's Avatar
it was a rover part from british atlantic. I will work on that darn filter. but if the filter was clogged, would i still have good pressure @ the rail?
Old Jun 19, 2010 | 11:14 AM
With out putting a fuel pressure gauge on when the engine shuts down, you really don't know what you have.
Old Jun 19, 2010 | 11:59 AM
musickjr's Avatar
I will go get a fuel pressure guage.
what should the pressure be?
Old Jun 19, 2010 | 05:46 PM
musickjr's Avatar
Checked the fuel pressure. It was 30 psi
