Disco II power cuts off for split second
Old Jan 24, 2010 | 06:43 PM
cellman01's Avatar
Default Disco II power cuts off for split second
i have a 2000 Disco that has started cutting out for just a split second. Started noticeing it when my radio would cut out for a second. Then when i have the disco in a pull i can feel the engine cut out for a split second. does it randomly. Dont see the tach drop it is so fast. Dont notice it in the engine when just running down the road. Only when in a pull. Anybody ever had this? Any suggestions?
Old Jan 25, 2010 | 01:41 PM
leadfoot's Avatar
Never had that problem, but if the radio cuts off, then you can pretty much rule out sparks plugs, cables, cols, fuel injectors and all th normal sects. Sounds more like a loose connection in the ignition switch system. I would start with the battery connection and work my way from there. What you describe is like disconnecting the battery momentarily.
lvshust
Aug 21, 2018 02:29 PM
luckyd77
Feb 27, 2012 09:33 AM
gtkansan
Apr 26, 2010 10:52 PM
rmshunter
Aug 27, 2008 11:33 AM
caspian
May 16, 2008 08:01 PM
