disco II problems
Old Oct 22, 2012 | 04:56 PM
avengermike's Avatar
4th Gear
Default disco II problems
hey guys the other day at the stop light my disco started to idle funny, i installed new wires and plugs but i still fill hesitation when i accelerate.
just bought a scannger 1360b innova, codes that came up
p1300
*p0154
p0134
*p0135
*p0155
p0305
p0307
p0160
p0141
p0161
p0139
p0159
*p1590
p0301
p0138
Thanks for any help...
Old Oct 22, 2012 | 06:02 PM
lr2001silver's Avatar
Banned
Damn thats alot of codes dude.... dud you have these codes before the new plugs and wires? nd which wires and plugs did you use? How many miles on truck?
Old Oct 22, 2012 | 06:11 PM
Banned
https://landroverforums.com/forum/di...ght=codes+list
Here you will find the list of codes you have quite a bit going on and need to give us some more info so we can help you trouble shoot
Old Oct 22, 2012 | 08:18 PM
Rover_Hokie's Avatar
I would vote for clearing them all, and then see which ones come up that are active and start from there. If they are all active, have fun.
Old Oct 22, 2012 | 10:59 PM
4th Gear
2001 Land Rover Discovery II 4.0 liter. 204k miles Installed sti wires. Don't recall plugs. All the codes are from before doing spark plugs and wires. The ones with the stars next to them were left behind. Land Rover still hesitates.
Old Oct 22, 2012 | 11:32 PM
Banned
Congratulations please join the 200k club!!!
Now good choice on wires!
You need to unplug all 4 of your o2 sensors and clean connections and then apply dielectric grease to insides of connectors and then plug them back together clear codes and drive threw a few cycles and let us know what happens.
Old Oct 22, 2012 | 11:59 PM
mx468's Avatar
Check your fuse in the engine. I had a ton of codes and strange idle problems and it turned out to be a blown 15amp fuse. If thats not the case clean or change your o2 sensors. I had a problem earlier this year with idling and it turned out to be the rear o2 sensors. Good luck!
Old Oct 23, 2012 | 06:18 AM
drowssap's Avatar
I agree with clearing all codes and start over, it would be hard to have 15 code and not have your dash lite up like a chrismas tree. JMO
Old Nov 11, 2012 | 02:22 PM
4th Gear
Default problems
hey guys so i still havent gotten around to put new o2s in but my new codes are:
P0301 cylinder 1 misfire
P1319 misfire with low/empty fuel drive cycle c: signal out of range - above
any ideas?
Old Nov 11, 2012 | 02:34 PM
Madlands's Avatar
I'm with mx468 check your f2 fuse under the hood, mine was acting like you described and it turned out to be just the fuse.
