Disco II starting to run hot...causes???
Old Jun 26, 2009 | 03:30 PM
jrkstore43's Avatar
OK, I spoke with Mike and I've checked a few more things and believe I've found the culprit....
The condenser fan for the A/C blew the 40A fuse, so it wasn't spinning at all. Only problem is I replaced the fuse and it blew immediately. I'm not an electrical expert, so what are the top causes for this and where do I start my troubleshooting???
Thanks!
Old Jun 26, 2009 | 04:52 PM
The fan has failed, assuming that there is no bare wire shorting out the fan it will need to be replaced using another Rover fan not an after market one.
Old Jun 26, 2009 | 05:01 PM
Try and spin the fan by hand, if it wont turn it is toast.
www.roverlandparts.com
www.autosportsunlimited.com
Old Jun 28, 2009 | 12:41 PM
jrkstore43's Avatar
I disconnected the fan and put a new fuse in. Drove around for a bit and the fuse didn't blow, so it appears to be the fan. I took the grill off and got in there and you bet, Spike, the fan won't turn at all.
Ah, the hunt begins for a new one! I'll head your advice, Mike, and stick with an OEM replacement.
Thanks!
Old Jun 28, 2009 | 04:48 PM
How much do you like to tinker?
Is the fan motor made by Denso?
I have been told that you can take the fan motor out of a Toyota and install it into your Rover fan housing and use the LR wiring.
I am not recommended this but if you wanted to tinker and see if it will work, you can get a Toyota fan from a Corolla or Camry out of a junk yard for like $10.
Old Jun 29, 2009 | 09:01 AM
jrkstore43's Avatar
Well, if tinkering means $10 versus $125, I'm in!
I just checked and yes, the fan motor is made by Denso. Any thoughts on what year Camry or Corolla I need to be looking for? And it would just be the fan motor, not the fan and shroud, right?
Old Jun 29, 2009 | 09:23 AM
I do not know what year Toyota you ned to be looking at.
I would just take my fan motor to the junk yard and start trying to match it up, there should be a model # printed on your fan motor and you can just match it up.
There may be others have use the same fan motor too, so look into all the imports, domestics will use domestic parts so you need to look at imports.
You may need to buy the whole fan and shroud but what you want is the motor.
You may need to cut the plug off the "new" fan and splice in your "old" plug but thats no big deal, a couple of wire crimps and heat shrink and you'll be good to go.
Old Jun 29, 2009 | 04:40 PM
jrkstore43's Avatar
Hey Spike, I just got a replacement condenser fan off a 2001 Disco for $80. I looked around the yard at a few Toyotas, but none of the motors matched up. A/C is running MUCH cooler now!!!! And, hopefully no more overheat issues...
Thanks for the help everybody!
Old Jun 29, 2009 | 05:23 PM
Sweet, $80 and drop right in is better than $125 any day.
Save your old one and just keep you eyes open for a new motor for it.
You might even beable to buy one at Radio Shack that will work.
Who knows, garage sales and flea markets are a tinker's best friend.
Old Jun 29, 2009 | 06:25 PM
jmt's Avatar
jmt
The A/C fan was locked up on my 03 when I got it but it never over heated. I got a pull-off for $50. Replacing it is a pain in the *** because the bolts are small and a little hard to get to, but can be done in the driveway with a few hand tools.
As far as I could tell, and 3 trips to different auto-parts stores in my area, it is not possible to replace the motor with a Corolla/Camry motor. I'm pretty sure that only works on the D1's or two fan set-ups.
I'm glad you got it straightened out.
